JasonXXX
Feb 06, 2012Aspirant
readynas and CRT TV
Hi, I want to playback the movies on my CRT Tv from readynas. is there any way to do so? do i have to do it through a tivo box? please help out. appreciate much
Feb 08, 2012Guru - Experienced User
There are several models, you should check the install guides at wdc.com
JasonXXX wrote: thank you guys for the replies!
sorry,im not very good with stuff like this.
after having done some researches,it seems out of those media players, the WD live is more affordable comparing to others
i dont think is necessary to buy the costly ones like xtreamer? i just checked its so expensive!
all i want is to play the movies from the HDD's i stored in my readynas ultra.
does the WD live include the 4 x RCA Phono Red White Yellow Black Lead Cable so that i can use them on my CTR TV?
thanks again
regards
Though generally, composite video uses 3 RCA phono (yellow for video, the other two for stereo audio). Component uses 5 RCA phono (three for video, 2 for stereo audio).
Not sure about 4 x RCA. Are you sure that all 4 are RCA? Generally I'd expect one to be S-video.
