Ogdjstltmein
Jun 23, 2013Aspirant
ReadyNAS as Media Player for Elderly Relative...
I want to use a ReadyNAS as a media player for an elderly relative. She doesn't use computers and doesn't like to use anything that requires a keyboard and mouse. She does have a small media player...
fastfwd
Jun 23, 2013Virtuoso
Ogdjstltmein wrote: She does have a small media player, which I bought for her, that operates with a remote control similar to a T.V. remote which she loves and which she's able to operate using its remote control to locate and play files from a USB stick .... The thing is, since I bought her this media player, I'm constantly having to update her memory stick .... Might there be a way to plug a ReadyNAS into this type of media player so that I can access a hard drive through this media player via its remote control? (it's only input is a USB port).
If the problem is simply that the USB stick doesn't have the storage capacity you require, why not replace the USB stick with a USB hard drive? You can buy a 500GB USB drive for approximately $60, and it should just work with the existing media player that your relative already enjoys.
