Dewdman42
Sep 13, 2025Virtuoso
Readynas as VM and build-essential
Ok here is a question. Does anyone know if there are any pre-made VM containers with ReadynasOS6 on them, and with build-essentially already installed into them also? Since apt can no longer get...
Sep 13, 2025Guru - Experienced User
Dewdman42 wrote:if ReadynasOS is open source
It isn't open source.
However, Netgear has modified various open source packages for use in ReadyNAS. Those are available here:
I've never downloaded the various VMs, but I believe Sandshark has.
