Dewdman42
Sep 13, 2025Virtuoso
Readynas as VM and build-essential
Ok here is a question. Does anyone know if there are any pre-made VM containers with ReadynasOS6 on them, and with build-essentially already installed into them also? Since apt can no longer get...
Dewdman42
once a long time ago, someone here recommended for me to use a VM for building stuff for Readynas and I actually had created a VM with build-essential and everything in there so that I could build stuff on the VM and test it before bringing any binary over to my actual unit. But I lost that VM image long time ago....
I can even vaguely recall someone here helping me use a VM to build some stuff I needed, but I just can't remember the details now. So...maybe grasping at straws, just trying to see if there is any way under the sun to get build-essential.
I have thought about also just making a jessie VM and try to build stuff there, In some cases that might work but not always where readynas has custom libraries of some kind that I would need to bind to, such as in particular libc appears to be. I could certainly try to build a new version of Python3 on a jessie VM and see if it works. ....it's a stretch. That's the main thing I need now for one particular purpose that would get my readynas back to the working order it was in before I did a factory reset.
Otherwise I've pretty much decided it can still function great as a backup serve and even as my primary SMB file server and it can even do plex streaming still, but still dependent on a secondary machine to run some services which I use to be able to run on this, but can't now. The only solution without build-essential is get a new NAS..but honestly I don't really want to do that right now, just because I can't decide which hardware I would get and I feel my readynas is still quite good hardware so I want to keep using it. Just wish I could build the odd thing I need to build for it, in this case Python 3.5+
