RPB123's avatar
RPB123
ReadyNas Audit Access Level
Hi All,
In the audit settings for our ReadyNas 312, I see there is an option for Audit Access Level.
If you tick the box what does this do compared to not having it ticked? Is write-only already selected as a defaul option
Presumably the read/ write option creates a larger log?
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    RPB123
    It seems the option is to specifically audit the access that is selected. Not ticking the box means all access levels will be present on the audit.
    HTH
    • Sandshark's avatar
      Sandshark
      Sensei
      Marc_V wrote:
      RPB123
      HTH
      That is certainly not intuitive and needs to be re-thought.  Assuming folks have read the manual (if it's even in there and they even know where to find an updated one detailing the new features) is not a good plan.
      I collection of check boxes for each audit function, all on by default, would seem appropriate.  That or radio buttons with the default option of "all".
ProSupport for Business
