linkup1
Aug 26, 2017Aspirant
ReadyNAS Business Pro Power Supply Replacement
Earlier this year my ReadyNAS got double booted in a very short period of time following a power outage that lasted longer than my backup. Afterwards it appeared the PS was dead. I did diligent res...
Sandshark
Aug 28, 2017Sensei
The post you referenced is for replacing the supply in an NVX, a 4-bay legacy system. Your 6-bay Pro takes an entirely different form factor, wiring, and wattage.
You need an SFX form factor power supply with at least 300W. The Seasonic is recommended if you can get one (it is apparently hard to get in some European countries). You must not change the wiring as is listed for the 4-bay supply in the reference message, but you will need a 6-inch standard 24-pin ATX extension. You may want to transfer the 90° Molex connectors from the old supply to the new to reduce the wire length for those connections and make installation a little cleaner.
linkup1
Sep 01, 2017Aspirant
Happens the Seasonic SS-300SFD is readily available and I sure wish I had looked at what I had before ordering the wrong PS.
The new Seasonic PS, like you mentioned, has different wiring. I mistakenly bought a 20-pin power extension so I am considering just splicing in wire to extend the ATX connector.
The new PS has three drive power connectors. Two have the double 4-pin Molex with the smaller style 4-pin connector on the end, like for floppies. The third power cable has a pair of SATA power connectors instead. Assuming no wiring changes were done like with the other NAS, I think I can get from A to Z.
Thanks.
