omichaels1
Mar 17, 2011Aspirant
ReadyNAS compatability with HP Officejet 5610 "all in one"
I'm considering purchase of a ReadyNAS DUO but need to use it as a print server for my HP Officejet 5610. This printer model is not listed on the ReadyNAS USB Printers Hardware Compatibility List ...
jtaylor1477
May 29, 2012Aspirant
This lists the printers compatible with NETGEAR print servers.
* Supported printers either use USB or parallel printing. Some use both.
* The new WGPS606 print server, however, supports other printers.
* Multifunction printers such as combination printer/copier/fax only support the printing function. This is true of all non-NETGEAR products, too.
* Except as noted, bidirectional features, such as reporting ink status to networked computers, are not supported.
* Other printers and features may be compatible, but NETGEAR has not tested them.
* You can use a browser or the Support search to look just for a printer number. E.g., search "660", instead of "Epson Stylus Color 660". You may find more than one model.
* A few printers are incompatible with most print servers, including NETGEAR's. Generally this is due to non-standard software such as CAPT and GDI.
__________________________
[ur=http://www.inkjetsuperstore.com/]hp printer ink cartridges cheap[/url]
