dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Nov 10, 2009NETGEAR Employee Retired
From other thread:
This would be interesting to try. May need to try this out sometime when I'm not so busy.
dekkit wrote: Further to my recent posts, i've found a link that indicates that it should be possible to create a Linux Live CD/DVD from an existing linux distribution (eg ubuntu / Debian)
http://ubuntuforums.org/showthread.php?t=688872
Therefore if the conversion process doesn't prevent the Ex2FUSE update from working, hopefully someone should be able to create neat bootdisk for an x86 PC that will have everything you need mount a perfectly working ReadyNAS Duo HDD ...
If anyone has local Linux install with the Ext2FUSE working, or wants to try from the VMWare image i put together (once people have confirmed it is working from them) have a try and let us know if you were able to successfully creat a bootdisk from it.
This might help to resolve Saxguy's issue and enable people to use the existing sata ports on your mainboard (rather than a Sata to USB cable)
