dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
Josch
Nov 11, 2009Aspirant
Josch wrote:
mdgm wrote:
Did you give the VM control of the USB disk and follow the steps outlined by dekkit to mount it?
Yes I tried it. My disc apears as sdb1 but I can't connect it - it seems that the filesystem is broken.
With the windows device manager I also see only one unreachabel partition.
Just a little description, what I have done:
I connected the disc via SATA/USB cable with a windows XP PC where I started Total Commander with ext2fs-Plugin. With this I was able to see the files on the disc but I wasn't able to browse into the created shares (e.g. /c/media).
After this I had the idea to connect the disc via the SATA/USB cable at the DUO. I thougt that the DUO could be able to read this sections. The DOU showed me the disc but it says that ther is no filesystem on it.
After this I tried it with the VM-Image and I get no access anymore!
