dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
huhu123
Nov 11, 2009Aspirant
Hi dekkit,
first of all many thanks for spending your time on this issue.
I've got your VMWare image working and can also connect to the ReadyNAS Duo harddisk using an USB/SATA-cable, but got an error
fuse-ext2: Can't read an inode bitmap while reading inode bitmap
after trying to mount the volume. I remember this error has been discussed in the first thread, but with no result there if I remember correct.
Any suggestions?
Kind regards,
Steffen
Any suggestions?
Kind regards,
Steffen
