dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Nov 22, 2009NETGEAR Employee Retired
dekkit wrote:
Is understood to be resolved by using a the 0.5 version of ext2fuse, so i'll recompile the kernal using the 0.5 and post another version of the image.
Great. When you post the new version of the image update the first post to point to it (you may wish to keep the old link there as an old version in case someone wants to look at it).
You may want to use version numbers to distinguish the newer version from the old e.g. 1.1
