dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
hahnson
Nov 27, 2009Aspirant
_vito wrote:
dekkit wrote:
Access the terminal and enter the following once the HDD has been attached (take note that your /dev/c may differ):
modprobe fuse
vgscan
vgchange -ay c
mkdir /mnt/lvm
ext2fuse /dev/c/c /mnt/lvm
there is a delay in output but then ..
"/dev/c/c is to be mounted at /mnt/lvm
fuse-ext2 initialized for device: /dev/c/c
block size is 16384"
I had some problems, since I am not a linux expert:
1) vgchange -ay c
gave an error 'Volume group "c" not found' I tried running
vgchange -ay
(for all volume groups?); is it correct?
2) the disk was under /dev/sdb so I command
ext2fuse /dev/sdb /mnt/lvm
but I got the response
/dev/sdb is to be mounted at /mnt/lvm
fuse-ext2fs: Bad magic number in super-block while trying to open /dev/sdb
and do not complete the command.
A bug or I am too clusmy?
Any clue?
Got the exact same problem, althou it finds an lvm c when i do vgscan, but i get
on the last command, help would be wery welcome
Edit: found it out, yu should mount the /dev/c/c not the /dev/sdd as i tried, no i can mount without error and can se the / tree of the drive, but if i say try to cd into home i get
"ext2fuse_dbg_msg: Bad address while reading inode "variuos numbers""
"ext2fuse_dbg_msg: Operation not permitted while reading inode "various numbers""
and the dirs are empty
when i ran the ext2fuse command i got
"fuse-ext2: Can't read an inode bitmap while reading inode bitmap"
