dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
_vito
Nov 29, 2009Aspirant
_vito wrote:
I had some problems, since I am not a linux expert:
1) vgchange -ay c
gave an error 'Volume group "c" not found' I tried running
I connected the HD directly to SATA controller and I am able to see it in group c inside VMWare now (maybe my SATA to USB connector did not work well).
I make all the steps up to the error
fuse-ext2: Can't read an inode bitmap while reading inode bitmap
and when I try to access from another terminal to /mnt/lvm I got the error
Operation not permitted while reading inode xxxxxxx
as reported to several other post.
I tried also to compile again the fuse-2.8.1, e2fsprogs-1.41.2 and ext2fuse-0.8.1, having same result.
Can someone help me?
