dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Nov 29, 2009NETGEAR Employee Retired
_vito wrote:
I make all the steps up to the error
fuse-ext2: Can't read an inode bitmap while reading inode bitmap
dekkit wrote:
The error:
Is understood to be resolved by using a the 0.5 version of ext2fuse, so i'll recompile the kernal using the 0.5 and post another version of the image.
If you wish to try this yourself you should use a 0.5 version of ext2fuse.
