dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
_vito
Dec 01, 2009Aspirant
mdgm wrote:
_vito wrote:
I make all the steps up to the error
fuse-ext2: Can't read an inode bitmap while reading inode bitmap
dekkit wrote:
The error:
Is understood to be resolved by using a the 0.5 version of ext2fuse, so i'll recompile the kernal using the 0.5 and post another version of the image.
If you wish to try this yourself you should use a 0.5 version of ext2fuse.
...and it worked!!!
I, not an experienced linux user, build from scratch a Ubuntu 9.10 VMWare machine installing e2fsprogs-1.41.9, Fuse-2.8.1 and ext2fuse-0.5.
Thanks a lot.
