dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
acmtn
Jan 05, 2010Aspirant
pingle wrote: Hi acmtn
I used a terminal to make an anonymous connection to your ftp site, and found the directory structure public/vm_Debian5_ext2fuse/singlefile as well as public/vm_Debian5_ext2fuse/multipart.
Unfortunately it looks as though the singlefile directory does not have access permissions for anonymous users.
Regards, Peter
Permissions on the single file fixed. Also added versions created with WinRAR - not sure if it makes a difference for the people having difficulty with .zip files, but I kinda want to put this to bed for myself. Will be taking down the site at the end of the week, so hopefully someone can get them copied off to a more permanent location. Thanks, Adam.
