dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
_vito
Jan 06, 2010Aspirant
giob wrote: _vito,
could you post instructions on how to use and compile ext2fuse 0.5 in Linux?
I have the same "fuse-ext2: Can't read an inode bitmap while reading inode bitmap" error.
Thank you
(If you are italian we could exchange private mails)
giob,
I just follow the instructions for all the packets as root:
./configure
make
make install
Anyway ext2fuse 0.5 is already compiled and the command is
ext2fuse -n /dev/c -m <mount_point>
as root.
