dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
fbmachines
Mar 18, 2010Guide
mdgm wrote:
The Duo is a 2 disk NAS so using X-RAID or RAID-1, all the data would be on disk 1. I don't think on the Duo it'd matter whether X-RAID or RAID-1 is used.
I wasn't sure if the proprietary X-RAID format could be understood by R-Studio.
mdgm wrote: Recovery a three disk or greater X-RAID array could be more complicated.
It does look a little complicated but it sounds like once you figure out the RAID parameters you can save the profile for future use.
Below is a 3 disk RAID 5 example...
http://www.unformat-unerase.com/Article ... ndex.shtml
