dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Mar 18, 2010NETGEAR Employee Retired
fbmachines wrote:
I wasn't sure if the proprietary X-RAID format could be understood by R-Studio.
So long as it can read EXT3 volumes using the 16k block size, it should be fine with using disk 1 from two disk X-RAID array.
fbmachines wrote:
mdgm wrote: Recovery a three disk or greater X-RAID array could be more complicated.
It does look a little complicated but it sounds like once you figure out the RAID parameters you can save the profile for future use.
Below is a 3 disk RAID 5 example...
http://www.unformat-unerase.com/Article ... ndex.shtml
I guess so. If someone has used parameters to successfully recover data of a 3 or 4 disk X-RAID array it would be good if he/she could post them.
