dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
TeknoJnky
Apr 16, 2010Hero
Has anyone considered, or attempted to use the methods to mount nv+/duo drives on a pro, via virtual box ?
ie, take nv+ drives, put in usb cases, all drives into a usb hub, connect to pro, get an applicable VM up in virtual box on the pro, mount the x-raid array ?
I think it would be pretty awesome to see done.
even better would be getting the all the required packages running directly on the pro and mounting (via usb) the x-raid drives directly without a VM.
