dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
EdinhoJr
Apr 22, 2010Aspirant
Hi Guys,
I need some help. I have a D-Link DNS-323 and I bought a ReadyNas DUO to replace it. I had too many troubles with D-Link and because of that I decide to switch them.
So I removed one disk from 323 and insert it into the readynas. I choose FlexRaid 0 with 500GB and left another 500GB to build a RAID 1 volume with both disks. After I copied the files from 323 to neadynas, I move the last disk to readynas.
Then my problems started. The first volume fail (not the disk), I tried to reboot, then readynas remove the partition information from the second disk and finally the readynas died. (So much luck)
So, I tried to move back the second disk into 323 but without success. I want to recover the information but until now I didn't got it. I'd tried the VMware recovery image and the R-Studio.
For VMware image, when I do the command vgscan, it find only the VG used on the VM.
For R-Studio, It finds many partition, but the files are cut and some of them didn't open. I tried to group all partition with 16k block into a virtual volume, but nothing different happens.
Please, I really need some help.
BR
Edson OLIVEIRA
Brazil
BR
Edson OLIVEIRA
Brazil
