dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Jun 08, 2010NETGEAR Employee Retired
Using X-RAID, disk 2 is the parity disk so for recovery using the VMWare Tool you'll need to use disk 1 (or if you have the necessary skills you may be able to copy the partition table from disk 1 onto disk 2). Not sure what the situation is with RAID-1.
