dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Jun 09, 2010NETGEAR Employee Retired
sushivore wrote:
i thought it was a miror of the data?
It is, if you leave the disks in the NAS, say disk 1 fails, disk 2 will still work fine. It's just only disk 1 will work for data recovery.
sushivore wrote:
i know the readynas is not a back up, but when i was tryin to save my data on usb or from ethernet i had many problems, so unfortunatly i was trustin my nas too much....
Yes you should backup your data regularly.
sushivore wrote:
about the support, i already contact them, they was useless for my problem, the first thing they told me to do ,it s an hard reset, holding reset 30sec, but that i might lost my data so.... not point to try it.
The 30 second reset would mean you lose your data. The 5 second reset would not. Start a new thread and post your case number. You should contact support again and ask them to escalate your case.
