dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
dekkit
Nov 28, 2010Aspirant
Hi BoyQuiet, its been a great to see the ReadyNAS community come together on this....and yes a detailed how-to-guide / video example is probably in order but unfortunately requires time but is on my to do list (unless someone else does it first!?!).
I'll eventually get around to editing the first post on this forum again to help make this clearer but some things to note (that have been mentioned elsewhere around here)
Things to note:
# Only the 1st disk of the duo will work in the VMware (usually in the 1st bay in a 2xbay duo).
Because of the way the RAID works in the duo, the second disk is considered the parity disk (apparently when you yank out the first disk, it will write the partition table to the 2nd disk - or something to this effect - and the duo will kick on). To view the contents of the 2nd disk, you'll need to use something like R-tools to scan and index the partitions on the 2nd disk.
# When you run the VMware, you'll need to run 2 x terminal windows. (which it sounds like you've done)
..the 1st will mount the ReadyNAS duo filesystem and will appear to 'hang' (with info about the size of the disk)
you then need the 2nd to access the files
# Accessing readynas drives plugged into your motherboard requires the _vito vmware version. You may need to google using VMware with internal hdds to ensure you configure _vito's image to meet your drive size. Please report any progress / success.
Dek
Things to note:
Dek
