dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
BoyQuiet
Nov 30, 2010Aspirant
dekkit wrote: The vito vmware version can be found in the first post of this forum :). I've copied the same link below
http://www.readynas.com/contributed/dek ... buntu9.rar
I haven't tried it myself, but worth a look if you need to try it with the hdds plugged directly into your motherboard.
Interesting that your system didn't kick over on a disk 1 failure. Where you using x-raid?
Thanks for the link - snowblind from reading the screen all day!
Yes it was x-raid. I x-checked that disks were in sync after power cycle. And powered down before removing the disk.
Will keep you posted on progress.
Thanks agin.
