dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
elgbert
Feb 14, 2012Aspirant
pc-addiict wrote: Your folders and file should be listed (if all goes well) in this terminal, you can now copy them to another HDD (usb, share etc that you have connected to the VMWare). Be aware there is a 4GB file limit on each filesize (a limitation of the ext2fuse).
I am using Ubuntu with fuseext2 as described here
http://home.bott.ca/webserver/?p=306
all was going well and I was getting my data, but I can not read files >4GB from my Duo drive. I can see from terminal that the directory sizes are listed correct, but they are not the sum of the file sizes. File sizes are listed as max 3.8 GB. I have tried to zip them with 2GB split, but the problem is reading them.
How can I resolve this? I really need my video files >4GB.
