dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
jausenbaugh
Jul 10, 2012Aspirant
Thank you! Thank you! The network adapter went out on one of my client's ReadyNAS Duos, and there was new data since the last backup. Using the acmtn Debian release, I was able to mount a volume from one of the mirrored drives hooked up via a USB to SATA adapter and copy data off. The only issue I had was not being able to browse the mounted volume from the GUI. So all of the browsing, copying, etc had to be done via the command line. Not a big deal, but I am not too experienced with Linux. Very relieved that this worked!
