dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
Dec 11, 2012Guru - Experienced User
Robocopy works pretty well for backing up the NAS up to Windows systems. It is incremental, and also has a mirroring option.
dekkit wrote: ...I'm thinking it might have just been easier if i had just started off with an old laptop and added a few usb NTFS formatted hdds in it, particularly as a windows user - anything that can go wrong with the duo is just so time consuming to fix / rebuild ..but then again moving TBs of data around was always going to be slow.
