dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
smgoma1
Mar 09, 2013Aspirant
rob_nelson wrote:
doyley86 wrote: Guys I have been struggling with this for months, I have found a simple easier way of restoring all my files using some free software called DiskInternals Linux Reader you can download it free from here:http://www.diskinternals.com/linux-reader/
it finds your drive straight away and allows you to copy off all your data! Hope this helps.
Cheers
Thanks for this recommendation. Linux Reader worked perfectly for me. After removing the drive from my Duo and connecting it via USB, I was able to access the files within minutes. It even worked with large files (5-10GB), which supposedly could not be transferred with some of the other recovery methods.
Just want to note that McAfee warned against the download when I tried to download it.
