dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
martinjochimsen
Apr 17, 2013Aspirant
doyley86 wrote: Guys I have been struggling with this for months, I have found a simple easier way of restoring all my files using some free software called DiskInternals Linux Reader you can download it free from here:http://www.diskinternals.com/linux-reader/
it finds your drive straight away and allows you to copy off all your data! Hope this helps.
Cheers
While waiting for the Ubuntu vmware image to download, I scrolled through the thread and found this post with the link to linux reader.
AMAZING!!!!
I have for weeks been fighting to get access to my disk after I made an upgrade on my ReadyNAS Duo.
I was beginning to loose hope and I thought I would give linux reader a shot (it wouldn't probably work anyway), but.....now I'm backing up everything form my disk.
Have saved more than 30 GB and still no error messages.
Thank you so much for this tip!!!!
Martin :-)
