dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
jplaville
May 06, 2013Tutor
Please help me.
If i virtualise the debain 5 image (the first in the post), it is ok.
But after in terminal of this image :
modprobe fuse
Nothing, but OK !?
vgscan
Reading all physcial volumes. This may take a while...
Found volume group "vmw.debian5" using metadata type lvm2
OK !?
vgchange -ay c
Volume group "c" not found
if i enter :
vgchange -ay vmw.debian5
6 logical volume(s) in volume group "vmw.debian5" now active
OK !?
mkdir /mnt/lvm
mkdir: cannot creat directory '/mnt/lvm/': File exists
rmdir and mkdir again.
OK !?
ext2fuse /dev/c/c /mnt/lvm
fuse-ext2fs: No such file or directory while trying to open /dev/c/c
And nothing...
If i enter :
ext2fuse /dev/sdb3 /mnt/lvm
fuse-ext2fs: Bad magic number in super-block while trying to open /dev/sdb3
(Because sdb3 is my partition to recovery).
modprobe fuse
Nothing, but OK !?
vgscan
OK !?
vgchange -ay c
if i enter :
OK !?
mkdir /mnt/lvm
OK !?
And nothing...
If i enter :
