dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Jul 23, 2014NETGEAR Employee Retired
manoj wrote:
This picture was taken after the memory test.
So the power LED was on solid?
Do you remember what version of RAIDiator was on this 600?
Did you follow the procedure described here?: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu#duonvnvx6600
Turn the NAS on, pressing and holding the POWER button for about 25 seconds (5 blinks of the disk LEDs) then release the power button. Do NOT press the RESET button.
Note that the boot menu did change in RAIDiator 4.x, so if running older firmware you might need to hold the power button for a blink or two less of the disk LEDs to trigger the memory test.
In RAIDiator 4.x Frontview (web-admin interface of the ReadyNAS) was changed to have NETGEAR colours and branding.
