dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Aug 10, 2014NETGEAR Employee Retired
manoj is this a 600 rev A or rev B?
If it's a Rev A you could remove the CF card and rawrite the firmware onto the CF card
Do you use Windows or Mac?
Do you remember what firmware you were running on the 600? Did the colours look something like this?: http://www.readynas.com/simulators/frontview/home.htm
Or were you running an older version that was Infrant branded?
