dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
petoulachi
Aug 27, 2014Aspirant
Hello,
Using a ReadyNAS V1 and Windows 8.1, which vm image would you recommand to recover my data?
My NAS is unavaible. Using Raidar, I can see it stuck in booting, or file checking, it depends. I've tried an OS reinstall (not a full wipe) with no success : now it is stuck in booting, but the IP configuration have been reset (new IP from my DHCP server instead of the fixed IP). So now, I want to recover data, and try to do a full reset then.
