dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
Aug 28, 2014Guru - Experienced User
Yes.
mdgm wrote: Well you've got a better chance of it working with disk 2 than with disk 1.
After the backup, maybe you can give us SMART stats on the disks.
Upgrading to current firmware, and doing a factory reset with solid disks is the obvious path forwards.
Or upgrade to a new NAS, and let the duo v1 go.
