yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
- RanonAspirantHi
Can the new 750Gig seagates(perpindicular) be used in the reeadynas--4 of them--Ranon - yoh-dahGuideWith p9, you can use up to 3 x 750GB. You'll need to wait for p10 to use 4 x 750GB or expand out the existing 3 x 750GB to 4 x 750GB.
- tempmjAspirantI have a HP 720 printer and it shows up and shares out. I install the driver and it shows the printer as ready.... When i print nothing comes out. Should this printer work, or is there a possibility of getting it to work?
Thanks! - SkywalkerNETGEAR ExpertHmm, I would think that HP would work. What Windows version are you using?
If it's not too inconvenient, you may want to continue to use the printer locally until the next RAIDiator version is released. It has some major changes on the printer support side of things. - jarrett_gorinAspirant
yoh-dah wrote: ReadyNAS Device Compatibility List can be found here: http://www.infrant.com/forum/viewtopic.php?t=66
I am using the ReadyNAS NV on my home network with a Linksys RV082 router/8-port switch/firewall and it works perfectly.
I just checked your compatible equippmentlist and saw that the Linksys RV082 is not listed (although several other Linksys models are). So I thought you may want to add this to your list. - yoh-dahGuide
jarrett_gorin wrote: yoh-dah wrote: ReadyNAS Device Compatibility List can be found here: http://www.infrant.com/forum/viewtopic.php?t=66
Thanks, I'll add it on. - ajb_advanceAspirantHi,
FYI, Samsung ML-1520 USB printer seems to work ok from WinXP. - bhoarAspirantIt just occurred to me that you could use the following color scheme in your compatibility list:
bold green = Infrant certified
bold yellow = Customer certified and/or Infrant reviewed (e.g. like the recent non-US RAM sources)
bold red = Incompatible
blue bumpers for recently added things...
-brendan - yoh-dahGuide
ajb_advance wrote: Hi,
Thanks! - kat_amsAspirantTo add to the compatiblity list...
Konica Minolta Magicolor 2400W colour laser printer works great on the Ready NAS.
