yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
- MarkusBAspirantThanks for the 2 new 1TB drives from WD in the HCL.
But there is a little fault: the correct model description is WD10EACS and not WD1000EACS.
Markus - Han_SoloTutor
MarkusB wrote: Thanks for the 2 new 1TB drives from WD in the HCL.
Markus
What!? I don't know what you are talking about it says WD10EACS. 8)
Thanks for pointing that out, I updated the list. :) - MarkusBAspirantI can report the following HD Enclosure working:
Sarotech FHD-354UF2 so called "HardBox M"
It's a USB 2.0 (and FireWire) Enclosure for 3,5 PATA Drives.
There exist also models for SATA.
I formatted from Frontview in FAT32 and EXT3, in both conditions it was reachable from Windows and OS X.
I have a used Maxtor 80 GB drive in it. (allowed up to 700GB)
Here is the Website with the Specs.:
http://www.sarotech.com/english/product ... _pata.html
Regards
Markus - lnbyAspirantwe have two readynas NV+ boxes (netgear branded) running 4.00c1-p2 [1.00a037] on X-RAID and all external drives are formatted to NTFS.
the following drives/enclosures are working flawlessly on both units and have been for 3 months+;
USB2 Drives
6x Seagate FreeAgent Desktop 500GB 7200RPM 8MB USB
ST305004FDC1E1-RK
1x LaCie 320GB 7200RPM USB2 8MB
301284K
Enclosures;
4x Akasa 3.5" ESATA ENCLOSURE
AK-ENP2SATA-BKU
The SATA drives for the above
4x Hitachi Deskstar T7K250 160Gb S300
HDS721616PLA380
only problem we've had is with a cheap belkin ups :lol: - apveenstraAspirantOn the page with the changes/fixes for the RAIDiator 4.01c1-p1 firmware (http://www.readynas.com/?p=48) under "Bug fixes" it says "2. Support Samsung 1TB drives"
Does this mean the Samsung 1T drives are now considered to be compatible?
They are still listed in the HCL as incompatible.
Alexander - chirpaLuminaryThe wiki is being phased out, updated HCL info is going here (which does list the Samsung): http://www.readynas.com/hcl/
- road2ruinAspirantHi chirpa,
Please add the Freecom MusicPal in category "Network Music Players". It works fine here.
Thx,
road2ruin - FirestoneAspirantI have four 1TB drives WDC WD1000FYPS-01ZKB0 in my ReadyNAS NV+ working with RIADator 4.01c1-p1 with no problems sofar. Only the expansion to recognise the big sizes took some hours. Odd thing is that RAIDar still mentions version 3.01 in the about box, but displays 4.01 in the info column.
BTW: of the 4 TB there will be 2.6 TB left in X-raid configuration. - odysseus1AspirantAny problems when using the ReadyNAS Duo with an Apple Airport Extreme Base Station (GigE ports)?
- aztlan_laAspirantYou add the HP Laserjet 3330 USB Printer to the compatible list. I connected it and added to 5 PC's they all print fine to it.
