yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
- christof2AspirantI looked at the list and wasn't sure what the squeezebox 1/2/3 was, can anyone tell me if the Logitech Squeezebox Duet is compatible?
- solarguy1AspirantFor what it's worth, I went ahead and got the Hitachi 1TB disks (2) and put them in. It seems to be working fine so far.
Cheers!
Roger D. - victoryariinaAspirantHi folks.
Got a question. It might seem stupid for someone, but i am really trying to understand the readynas stuff, hoping to buy one in the future. :D
OK. here we go... Compatibility list.
There are not that many Netgear routers in this list. So if i planing to have nas duo (or any other nas) and having for ex. wpn824, it will not work for me? According to that, here is the BIG info request:
are there any special requirement for the router to be in the compability list??? OR this list is build after the users experiment?
Best regards
//V. - mdgm-ntgrNETGEAR Employee RetiredThere are so many routers out there that it's impossible for NetGear to test them all and add all of the ones that work to the list. Most routers work fine particularly the newer they are.
- InterClawAspirantAny idea when 2TB drives will get official support? I'm running out of space...
- manfredellAspirant
InterClaw wrote: Any idea when 2TB drives will get official support? I'm running out of space...
It sure is taking a long time! - ekalishAspirantThe MAXTOR One Touch 4 Plus 1 TB USB Drive once formatted works perfectly.
- Cronus130Aspirant
manfredell wrote: InterClaw wrote: Any idea when 2TB drives will get official support? I'm running out of space...
+1 - Han_SoloTutor
The add-on to allow use of the WD RE4-GP drives is now available in the Hard Drive HCL. Currently the only units not approved to use with these drives are the NV+, Duo or the 3200. We however should have support for these systems soon. - manfredellAspirant
Han Solo wrote: InterClaw wrote: Any idea when 2TB drives will get official support? I'm running out of space...
What about the WD20EADS ???
