yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
- yoh-dahGuide
kat_ams wrote: To add to the compatiblity list...
Konica Minolta Magicolor 2400W colour laser printer works great on the Ready NAS.
Thanks! - woodstockAspirantThe following all work with my NV (v3.00c1-p2):
USB HARD DISKS / ENCLOSURES
Wolverine 2040 (enclosure contains 40GB Toshiba MK4025FAS laptop drive)
USB FLASH
SanDisk Cruzer mini 1GB
SanDisk Cruzer micro 512MB
VisionTek flash drive 512MB
USB PRINTERS
HP OfficeJet 7210 All-in-One
USB UPS
Dynex DX-800U (800AVR)
USB CAMERAS (new section?)
FujiFilm FinePix F10 (it appears as: USB_FLASH_# FUJIFILM USB-DRIVEUNIT) - yoh-dahGuide
woodstock wrote: The following all work with my NV (v3.00c1-p2):
USB FLASH
USB PRINTERS
USB UPS
Thanks!
For the UPS, did you run-down the battery and check for graceful shutdown? - woodstockAspirantNot yet. The UPS is plugged into an outlet that is blocked by a heavy bookcase -- so it may be awhile before I can unplug it. I don't really want to start flipping breakers. :)
Here's something odd I just noticed about the UPS. On the Health page, it claims the battery charge is 120%/45min. 120%? - dedaloAspirantI have linked my two USB printers on ReadyNAS 600 and they are working.
Infrant ReadyNAS 600
RAIDiatorâ„¢ v3.00c1-p2 [1.00a131]
HP Deskjet 6540
HP officejet 5510 - yoh-dahGuide
dedalo wrote: I have linked my two USB printers on ReadyNAS 600 and they are working.
HP Deskjet 6540
HP officejet 5510
Thanks! - yoh-dahGuide
woodstock wrote: Not yet. The UPS is plugged into an outlet that is blocked by a heavy bookcase -- so it may be awhile before I can unplug it. I don't really want to start flipping breakers. :)
OK, I'll hold off on putting the UPS in our list. I haven't seen these UPS's before. Do you know if they're rebranded? - tg3AspirantI can confirm my GigE switch works fine with the ReadyNAS NV.
Netgear ProSafe GS116 (GigE, Jumbo Frames, 16 port, non-managed).
Have not tested the jumbo frame feature.
Much to my delight, GigE works fine on a home Cat 5 network installed nearly 10 years ago. - Derek_K_AspirantI have successfully shared the printer in my Samsung SCX-4521F all-in-one under XP. Printing works fine and is pretty fast.
Is it even possible to share a scanner over the network? I wouldn't think so. - yoh-dahGuide
tg3 wrote: I can confirm my GigE switch works fine with the ReadyNAS NV.
tg3, have you verified performance with IOMeter? It'll be good to get jumbo frame numbers before we put it on the list. Thanks!
