  • To add to the compatiblity list...
    Konica Minolta Magicolor 2400W colour laser printer works great on the Ready NAS.
  • ajb_advance wrote:
    Hi,
    FYI, Samsung ML-1520 USB printer seems to work ok from WinXP.
    Thanks!
  • It just occurred to me that you could use the following color scheme in your compatibility list:
    bold green = Infrant certified
    bold yellow = Customer certified and/or Infrant reviewed (e.g. like the recent non-US RAM sources)
    bold red = Incompatible
    blue bumpers for recently added things...
    -brendan
  • jarrett_gorin wrote:
    yoh-dah wrote:
    ReadyNAS Device Compatibility List can be found here: http://www.infrant.com/forum/viewtopic.php?t=66
    I am using the ReadyNAS NV on my home network with a Linksys RV082 router/8-port switch/firewall and it works perfectly.
    I just checked your compatible equippmentlist and saw that the Linksys RV082 is not listed (although several other Linksys models are). So I thought you may want to add this to your list.
    Thanks, I'll add it on.
  • Skywalker's avatar
    Skywalker
    NETGEAR Expert
    Hmm, I would think that HP would work. What Windows version are you using?
    If it's not too inconvenient, you may want to continue to use the printer locally until the next RAIDiator version is released. It has some major changes on the printer support side of things.
  • I have a HP 720 printer and it shows up and shares out. I install the driver and it shows the printer as ready.... When i print nothing comes out. Should this printer work, or is there a possibility of getting it to work?
    Thanks!
  • With p9, you can use up to 3 x 750GB. You'll need to wait for p10 to use 4 x 750GB or expand out the existing 3 x 750GB to 4 x 750GB.
  • Hi
    Can the new 750Gig seagates(perpindicular) be used in the reeadynas--4 of them--Ranon
ProSupport for Business
