hyopained
Nov 20, 2023Aspirant
ReadyNas Duo - unable to to access via Router
Hi all, I'm in desperate straits. We have many volumes of media (photos, videos) on our ReadyNas Duo that need to be accessed. We stopped using the device a few years back and the local SSD drive...
Nov 21, 2023Guru - Experienced User
Sandshark wrote:
. Alternately, you can use a package like R-Linux for Windows to read the drives in Windows and recover the data.
I suggest doing this first.
This will only work on the primary disk - the RAID mirror will show the operating system partition, but not the data. So you might need to try both.
Don't attempt to "convert" anything from linux formatting. This tool should be able to find the drive and the files, even though Windows can't mount it.
Once you've off-loaded the data, we can sort out whether the NAS can be resurrected or not.
