rettroo
Oct 14, 2013Aspirant
Readynas DUO 1HDD failure
Hi, i have try to solve my problem in the german forum but i have got no response... i have a readynas duo with 2 1TB harddiscs. All the time with Raid 1, every time on the side of saftey. But...
Oct 15, 2013Guru - Experienced User
rettroo wrote: yes
StephenB wrote: You are still running XRAID (e.g., RAID-1)?
Then your data should still be intact. Are you saying you can no longer access it?
Also, your log says you have a 1 TB Samsung drive in slot 1, and a 500 GB WDC drive in slot 2. Is that correct?
