rettroo
Oct 14, 2013Aspirant
Readynas DUO 1HDD failure
Hi, i have try to solve my problem in the german forum but i have got no response... i have a readynas duo with 2 1TB harddiscs. All the time with Raid 1, every time on the side of saftey. But...
Oct 15, 2013Guru - Experienced User
Ok. Try using linux reader on disk 1 (on a Windows system). http://www.diskinternals.com/linux-reader/ It should be able to read the data (assuming an intact file system, and raid-1 or xraid). There is more information here: http://home.bott.ca/webserver/?p=306
Though if you were actually running raid-0, your data is gone.
BTW, do you have a duo v1 (sparc processor, running 4.1.x firmware) or a v2 (arm processor, running 5.x.x firmware). Here's a guide: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
