hamslice
Jul 23, 2020Aspirant
ReadyNas Duo 2110 v1 placement and connection
I got my legacy Nas up and running with help from this forum, thanks! Now I'm just considering the permenant placement, as it is fairly loud where the virgin hub is in the living room. Ideall...
- Jul 23, 2020
hamslice wrote:
Is it also possible to connect the Nas to a second router that uses the same Wifi connection, or is that not a thing?
You could also use a wifi extender that has an ethernet out. If you have a mesh (for example Orbi), you can similarly connect the NAS to the ethernet port in the Orbi satellites.
Both approaches can give reasonable performance, but mileage does vary. Powerline can be hit-or-miss - performance depends on wiring details and circuit loading. WiFi performance of course also varies - depending on the path between the router and extender, interference from neighbors sharing the spectrum, etc.
Jul 23, 2020Guru - Experienced User
hamslice wrote:
Does anyone have any creative solutions for this?
There is flat ethernet cable that can run along baseboards and under carpet.
You could also try powerline networking, and see if that gives you adequate performance. Then you could try other locations. You'd want something with gigabit ethernet ports. One of the 1000, 1200, or 2000 models here for example: https://www.netgear.com/home/products/networking/powerline/ Longer term you'd probably want to run ethernet, but this would get you started.
If you do end up running your own cable inside walls, you'll want to use appropriate cable - plenum grade if you are running in existing ducts, riser grade will work if you are just running in-wall.
My own NAS are in my basement.
hamslice
Thanks again for your help Stephen,
Those were the options I was thinking of - so good to confirm I am on the right track.
- StephenBJul 23, 2020Guru - Experienced User
- hamsliceJul 23, 2020Aspirant
Thanks Stephen!
Will have a go :)
- SandsharkJul 23, 2020Sensei
If you already have that second router, many can be configured as a bridge for the existing network and it will work that way. Setting it up on a different router as a separate network will give you all kinds of grief with the systems accessing it unless they don't need access to anything else.
