Rosbif1
Jun 10, 2012Aspirant
ReadyNas Duo and Seagate ST3000DM001 3T
Hi, I've just fitted 2 x 3T ST3000DM001 HD into my readynas duo but only 746GB are available. What am I doing wrong? Thanks
Rosbif1
I've had the Duo v1 for a while but never really used it... I stored stuff locally on my media center instead... until the HD died and decided to use the NAS.
The Nas was fitted with 1x 1.5TB drive. (That was hardly used).
I removed the 1.5TB drive from the NAS, when it was switched off and then fitted the 2x3TB. Did a factory reset as well.
Only 746GB detected.
What's the best thing to do? Get a ReadyNas Duo V2 or better?
