Rosbif1
Jun 10, 2012Aspirant
ReadyNas Duo and Seagate ST3000DM001 3T
Hi, I've just fitted 2 x 3T ST3000DM001 HD into my readynas duo but only 746GB are available. What am I doing wrong? Thanks
mdgm-ntgr
Jun 10, 2012NETGEAR Employee Retired
Either fall back to using 2TB or lower capacity drives or get a new NAS. Do note that the RAID format of the Duo/NV+ (ARM) and the Ultra/Pro (x86) is different to that of the Duo v1. So you would need to do a factory reset in the ARM or x86 NAS to wipe the 3TB disks.
