pjfg
Jul 30, 2014Aspirant
Readynas DUO and WD EARX 2TB
I have an old ReadyNas Duo v1 that originally had 2 x WD EARS 2TB drives in raid1. After a year or two drive number 2 died, still under warranty and was replaced by WD with a EARX 2TB, so nearly identical. That synced fine and was running without issue for some time. Now my Duo report through frontview that the drive has died. I removed the drive, put it in my desktop pc and ran WD's disk test tool. This found a couple of bad sectors which it claims to have repaired. Popping the disk back in the Duo initially syncs but soon fails again. Repeated this a few times, and always the same result. In the desktop pc the drive checks out ok - I can write zeroes to whole drive, re-run disk scan with no errors. Smart data, qucik and extended smart tests show no errors. Yet the drive continues to fail in the NAS.
Any ideas? This disk is apparently compatible according to Netgear, but there have been frimware upgrades for the Duo since. Is it time to give up on the Duo and invest in something newer?
- StephenBGuru - Experienced UserWhat do the SMART stats say for the drive?
What firmware are you running on the NAS? - Marto731AspirantPJ,
It sounds that you have disk errors, so I would not give up on the Duo.
Can try a 3rd disk in Bay 2 for comparison.
Select your model # under "Legacy" on this list.
http://kb.netgear.com/app/answers/detail/a_id/20641
Thanks, Marto - pjfgAspirant
Attribute name Real value Current Worst Threshold
01 Read Error Rate 0 200 200 51 00000000C9 Good
03 Spin-Up Time 6750 ms 165 164 21 0000001A5E Good
04 Start/Stop Count 32,542 68 68 0 0000007F1E Good
05 Reallocated Sectors Count 1 200 200 140 0000000001 Good
07 Seek Error Rate 0 199 187 0 00000000D2 Good
09 Power-On Hours (POH) 654d 9h 79 79 0 0000003D59 Good
0A Spin Retry Count 0 100 100 0 0000000000 Good
0B Recalibration Retries 0 100 253 0 0000000000 Good
0C Device Power Cycle Count 35 100 100 0 0000000023 Good
C0 Power-off Retract Count 26 200 200 0 000000001A Good
C1 Load/Unload Cycle Count 2,119,642 1 1 0 00002057DA Good
C2 Temperature 32 °C 118 101 0 0000000020 Good
C4 Reallocation Event Count 1 199 199 0 0000000001 Good
C5 Current Pending Sector Count 0 200 200 0 0000000000 Good
C6 Uncorrectable Sector Count 0 200 200 0 0000000000 Good
C7 UltraDMA CRC Error Count 0 200 200 0 0000000000 Good
C8 Write Error Rate / Multi-Zone Error Rate 0 200 200 0 0000000000 Good
The firmware is the latest, version 4.1.13
I don't have another 2TB to test in the now empty bay 2. Will any harm come of inserting a smaller drive (I think I have a 160 or 250 spare) while the system is configured for RAID1? - StephenBGuru - Experienced UserYou can't insert a small drive.
- pjfgAspirant
StephenB wrote: You can't insert a small drive.
Well, obviously I can, physically. I'm just curious about the implications. Will it simply ignore it, and spit out an error, or would doing so cause data loss to the remaining drive? Obviously it's never going to sync any data with a smaller drive, but if it was happy I could at least test that sata channel by mounting the disk and filling it with some data.... - StephenBGuru - Experienced UserIf you want to test the channel, then power down the NAS and remove the existing drive. Then install the smaller one in slot you want to test. It will do an install, create a volume, which you can then test as you like.
When done repeat the process (power down, remove the small drive, and replace the existing drive in the original slot). - Marto731AspirantA different thread discussing use of a small disk with other larger disks, in RAID 5 is linked here.
Can a "downgrade" to a smaller drive cause my NV+ problems ?
http://www.readynas.com/forum/viewtopic.php?f=65&t=77143
Support would be totally opposed to use of a smaller Giga/Terabyte drive.
Regards Marto.
