1_beaugroup_com
Aug 23, 2014Aspirant
ReadyNAS Duo. disk 2 dead
Have ReadyNAS Duo. Orig 2# Seagate Barracuda 7200(rpm) ST31000528AS, 1TB, SATA3Gb/s cache 32MB. Disk 2 of 2 shows DEAD on Yahoo widget. can I purchase, Western Digital 1TB, WD1002FBYS RE3 SATA 3Gb/s,...
mdgm-ntgr
Aug 23, 2014NETGEAR Employee Retired
Yes. Any disks from the compatibility list of equal or greater capacity should be fine.
Remove the dead disk, unscrew it from the tray, screw the replacement into the tray and add it while the NAS is on. If the tray is stuck please see http://www.readynas.com/forum/viewtopic.php?p=30550#p30550
Yes. You should see that the LEDs show that the disk is dead as well.
