tokel
Nov 10, 2019Aspirant
Readynas duo hard drive failure
Hello! I have a ~10 year old readynas duo (v1 or v2) with 2x 1tb hard drives in. Now it has not been powered for many years, and I want to get the data of the disks. However, when I boot I get this (...
- Nov 10, 2019
You can try powering down the NAS and booting up with only disk 2 installed (keeping it in slot 2).
You can also connect disk 1 to a windows PC, and test the disk with vendor tools (lifeguard for Western Digital, seatools for Seagate). If it is readable, you can extract data with r-linux for windows ( https://www.r-studio.com/free-linux-recovery/ )
Nov 10, 2019Guru - Experienced User
tokel
Thanks for the reply, that did the trick (only running with disk 2)! Now I'm copying all files to a safe place. I'm thinking about buying a SATA->USB adapter. Do you know any good software (windows or linux) to test the failed hard drive to see if it's actually not working?
If I do a factory reset of the device now, where is the OS stored? Is it stored on some internal drive, or is it stored on the HDD?
- StephenBNov 10, 2019Guru - Experienced User
The OS is stored on the hard drive(s) in a small partition that isn't normally accessible.
Having an adapter like that is often useful. For disk testing, I use Lifeguard (Western Digital) and SeaTools (Seagate). There are other options out there (HDDScan being one), but generally I stick with the vendor tools.
