OZrevhead's avatar
OZrevhead
ReadyNAS Duo has stopped working
Hi, I have a ReadyNAS Duo RND2000 v2 with 2 1TB drives, I tried to access it today and its not on my network map anymore. It was silent with network activity lights flashing and no lights on the front. I pressed the power button and the fan revved up as if it was restarting but the fan stayed elevated and did not proceed to boot up. I pulled the plug and tried to boot it up again, the fan stayed elevated for about 5 minutes then dropped maybe half way (still audible) so I had a look at the front panel lights seem to be blinking code 33 (3 long, 3 short). I saw no mention of codes in the manual. Can anyone help me with the code definition and how to rectify it? Any help would be great. Thanks.
      • OZrevhead's avatar
        OZrevhead
        It was a while ago when I set it up but I believe I mirrored the drives, will the Linux reader still work on seperate drives too?
        If a drive was faulty wouldnt the NAS still boot up? I cant access the interface either.
  • StephenB's avatar
    Many v1 users mistakenly think they have a v2.  There's  guide here you should check: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
    The LED code for the duo v1 is below.  I'm not sure if it is the same for the v2.
    LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by a 1 second delay, followed by a number of slow blinks.  The number of slow blinks will be the error code.
    Current error codes:
    1 – Vendor mismatch
    2 – No disks detected
    3 – Bad contents on root partition of disks
    4 – Flash error
    5 – Unsupported RAID configuration
ProSupport for Business
